TwinTurbo.NET: Nissan 300ZX forum - Are the Shafts stuck on the Spline?..
Cjw3
on July 30, 2013 at 7:26 PM
stuck rear half shafts
posted by hixso
on July 29, 2013 at 12:51 PM
Here is an Overview of an NA left rear.. The hub just unbolted and slid off the splines on this one.. after the Axle Bolt was removed..
http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=1135242&forum=technical&dtSearch=4
Cj
hixso
12:51:55 07/29/13
gotta use a heavy mallet and hit it (n/m)
inf
16:34:31 07/29/13
although if that doesn't work you might need to wedge it out (n/m)
inf
17:31:22 07/29/13
Re: although if that doesn't work you might need to wedge it out
wild_maxx
19:59:50 07/29/13
Re: Re: although if that doesn't work you might need to wedge it out
hixso
08:17:35 07/30/13
Are the Shafts stuck on the Spline?.. -
Cjw3
19:26:42 07/30/13
