TwinTurbo.NET: Nissan 300ZX forum - Elbow is press fit (use some pliers and twist it)
Subject Elbow is press fit (use some pliers and twist it)
Posted by -Grimm- on July 29, 2013 at 3:12 PM
  This message has been viewed 195 times.
In Reply To Remove 90 degree elbow, install elbow onto hose. posted by 90GoldZ on July 27, 2013 at 07:26 PM
Message Or you could just delete the rear exhaust PCV lines with a 3/8" NPT plug. Already has the PCV lines from both intake valve covers...
Use a 1/4" NPT plug for the manifold side. Drill tap both out first, don't overtighten or you risk cracking the cast manifold.
[ http://z32.wikispaces.com/PCV+Delete ]
