| Message |
your adjustment at the master is probably to tight. You need to back it off some, Re bleed and try again to fine tune the adjustment. Since your adjustment is probably way out of wack, Remove the clevis pin, Adjust until the hole in the pedal and the hole in the clevis line up with the pedal in the up position and re insert pin, Bleed system and go from there.
