Hello so I just finished rebuilding my motor Ielted pistons in a 95tt. I got the heads re done and bought a low mile doner motor for the block a Tt just a 40p I used all my 95 parts on it other than the block itself and I kept the crank it. Well I put my unorthodox under drive pully on and the timing marks are not adding up. But I have checked twice and the pil pump gear and the cam gears are all dead on there marks. I did use my 95 oil pump and gear as well the blocks on all the tts are the same as well as the cranks correct ? URL link underneath
