TwinTurbo.NET: Nissan 300ZX forum - Should be cracked open *just* enough for fluid to come out.
Subject Should be cracked open *just* enough for fluid to come out.
Posted by PCVI on July 25, 2013 at 10:49 AM
  This message has been viewed 171 times.
In Reply To speed bleeder question posted by hellraz0r1337 on July 24, 2013 at 03:52 PM
Message I used a speed bleeder last time and had no issues. Before that I used a different method.
Instead of running a tube from the nipple to the bottle, get a long piece and stick it in the reservoir to create a closed loop. Open the nipple wide open and power flush it. You won't waste any fluid, and makes it much harder for any tiny air bubbles to get trapped because you're forcing so much fluid though the line.
You'll need a helper to make sure the reservoir stays topped off, or some other means to hold extra fluid when you first start. I believe I taped a gigantic funnel upside down over my reservoir.
