TwinTurbo.NET: Nissan 300ZX forum - Forgot to add - sounds like the alty bridge rectifer has an
Subject Forgot to add - sounds like the alty bridge rectifer has an
Posted by jzack on July 23, 2013 at 8:32 PM
  This message has been viewed 200 times.
In Reply To 12.9v is a little low - should be more in the 13.6v to posted by jzack on July 23, 2013 at 08:26 PM
Message issue. If it's bad - it will cause the battery to drain down pretty quickly (and not charge right either). Easy to test with a digital meter if it can measure DC amps.
Disconnect the battery's negative terminal and measure the car's current draw - all doors closed, hatch closed, all lights off including interior, etc. If more than .050 amps (50 mA) there's an issue, report back what you test. A bad alty will be drawing down around 2 amps or so even with the car off.
