TwinTurbo.NET: Nissan 300ZX forum - I would get a 2nd check on the alternator.
z32z
on July 23, 2013 at 8:26 PM
I'm only getting ~12.9dcv when engine is running!!
posted by Da Flash
on July 23, 2013 at 03:32 PM
You may have got the new guy that is learning how to use the tester. Your problem sounds like a weak alternator to me. Keep us posted.
Da Flash
15:32:06 07/23/13
Re: I'm only getting ~12.9dcv when engine is running!!
craigz96tt (SC)
15:52:15 07/23/13
Re: Re: I'm only getting ~12.9dcv when engine is running!!
Da Flash
15:59:24 07/23/13
I'm going through something similar. Do you have any lights
craigz96tt (SC)
19:43:58 07/23/13
12.9v is a little low - should be more in the 13.6v to
jzack
20:26:27 07/23/13
Forgot to add - sounds like the alty bridge rectifer has an
jzack
20:32:36 07/23/13
Re: Forgot to add - sounds like the alty bridge rectifer has an
Da Flash
14:40:14 07/24/13
Since all looks to (maybe) OK with the alty - I'd lean
jzack
18:37:18 07/24/13
Re: Since all looks to (maybe) OK with the alty - I'd lean
Da Flash
22:17:50 07/24/13
Optima's don't have the best of track records -- folks
jzack
22:34:10 07/24/13
Re: Re: Since all looks to (maybe) OK with the alty - I'd lean
Sportzcoop
15:26:48 07/28/13
I would get a 2nd check on the alternator. -
z32z
20:26:53 07/23/13
Re: I would get a 2nd check on the alternator.
Da Flash
21:19:46 07/23/13
