TwinTurbo.NET: Nissan 300ZX forum - Second Emissions Test in VA Failed (but much better)
Subject Second Emissions Test in VA Failed (but much better)
Posted by tomsbradford on July 23, 2013 at 6:10 PM
  This message has been viewed 300 times.
Message Implemented several brilliant recommendations in the attempt to pass emissions here in Northern Virginia.
The first test failed HC at low speed and failed CO% and NO at higher speed. I then ran a full tank of gas with “Guaranteed to Pass”, retarded the timing, and pulled the vacuum hose trick. The second test was better - much better NO results - and passing all but the low speed HC test. See the following:
Limit / 1st Reading / 2nd Reading / Result
15 MPH
HC: 92 / 160 / 105 / FAIL
CO%: 0.37 / 0.48 / 0.29 / PASS
NOX: 1200 / 379 / 178 / PASS
25 MPH
HC: 100 / 89 / 84 / PASS
CO%: 0.53 / 0.45 / 0.53 / PASS
NOX: 1167 / 1667 / 675 / PASS
Now, I got to tell you that I checked timing the between tests and the timing was reading 25 deg. BTDC. Weird. Not pinging! I turned the exhaust cam sensor all the way clockwise and could only get to 15 deg. BTDC; and that’s where I left it for the second test. Could it be that the timing belt is off. Maybe I’m checking the timing wrong with the induction clip on the three wires running to the coil pack. Would running the next test with more alcohol mixed with the gas reduce the HCs? What to do? Any thoughts?
