TwinTurbo.NET: Nissan 300ZX forum - Maybe leaking from the PCV's? I had some oil that...
Subject Maybe leaking from the PCV's? I had some oil that...
Posted by rmp459 on July 22, 2013 at 11:19 AM
  This message has been viewed 164 times.
In Reply To Has anyone experienced turbo failure on a brand new set? posted by Stanky on July 21, 2013 at 02:46 AM
Message seeped through the threads when I would boost the car above stock levels. You could see the little bit of oil that would leak out and down to the actualy turbo pipes/turbos and bead up down there.
You really need a small mirror to check the bottom of the valves, but I had to pull mine, clean them up and use some rtv on the threads to get a good seal.
