TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Heat shield is probably touching the shaft/wheel
Subject Re: Re: Heat shield is probably touching the shaft/wheel
Posted by wild_maxx on July 20, 2013 at 4:59 PM
  This message has been viewed 158 times.
In Reply To Re: Heat shield is probably touching the shaft/wheel posted by wild_maxx on July 20, 2013 at 02:09 PM
Message Thanks for the tip Doug. Once I tightened the replacement turbine housing down all of the resistance behind the impeller shaft was gone. It's spinning as well as a stock journal bearing turbo should. :)
