TwinTurbo.NET: Nissan 300ZX forum - The 1st time you remove the plenum takes the longest
Subject The 1st time you remove the plenum takes the longest
Posted by 300ZMang on July 17, 2013 at 12:13 PM
  This message has been viewed 221 times.
In Reply To Injector trouble posted by Tango Mike on July 17, 2013 at 10:46 AM
Message due to all the stock components being in place and needing to be removed. Upon installation you can do many deletes/by-passes which make install (and 2nd removal when necessary) much easier.
Once the plenum is off, the injectors, fuel rail, etc. are easy to access and it's not a complicated job at all the change injectors.
A Z expert can do this in less than 8 hours, and will get it buttoned up without issues. Anyone who's never done it will take longer (as expected) and might have issues getting it running right when all together.
If just one of your injectors crapped out, search the "dremel method".
Many have used this method successfully without any drawbacks.
