TwinTurbo.NET: Nissan 300ZX forum - Help with Dashboard Lights
Subject Help with Dashboard Lights
Posted by f1ym4n on July 13, 2013 at 3:15 PM
  This message has been viewed 366 times.
Message Hello,
Here's the story..
Sent my car to the body shop with no RED lights on the dashboard showing, only the CEL for a speed sensor (will fix that soon). They did lose one of the bulbs from the hatch lights that shines inside and I have not replaced that yet, and maybe this is causing the issue as well.
I have uploaded the picture below of which lights appear. The one for the third brake light and the BRAKE light which usually comes on for the parking break.
Dash lights
I know the hatch trim pieces and tailights were removed at the bodyshop and all exterior lights WORK, OEM Bulbs for third brake light, parking break is DOWN.
Also i found this connector loose which im guessing is for the brake fluid low sensor? put when i put it in, it just goes all the way through the master cylinder. How do correctly insert this into the hole under the MC? This is the sensor
Brake fluid sensor
Last bit of info, as I drive, the lights flicker slightly so im thinking maybe these two are on the same circuit and a ground is touching something to trigger them.
Thank you, let me know what you all think!
Vadim
