TwinTurbo.NET: Nissan 300ZX forum - Re: Nismo oil cooler question
Subject Re: Nismo oil cooler question
Posted by Dane (Houston) on July 13, 2013 at 2:06 AM
  This message has been viewed 171 times.
In Reply To Nismo oil cooler question posted by pilikua on July 12, 2013 at 11:40 PM
Message probably because is a universal nismo cooler. and it wont show a pressure difference because its not under pressure, its an open return into the pan. the restrictor helps hold oil in the cooler so it doesnt flow through to fast and has time to cool.
id modify the system with a sandwich to return to the sandwich and not the pan for this has been discussed to help cut aeration and offer full time oil cooling not rpm/pressure based operation. as the factory tree opens the valve to the cooler system and bleeds off oil that could be pushed into the primary system if a sandwich style system is used in place.
Like NAs z32s with cooler systems installed.
Click here to e-mail me!
