TwinTurbo.NET: Nissan 300ZX forum - More smoothing than extreme porting....
Subject More smoothing than extreme porting....
Posted by Z ONLY1 on July 10, 2013 at 5:54 PM
  This message has been viewed 133 times.
In Reply To A couple of thoughts: No reason to clean before porting. posted by zellamay on July 10, 2013 at 04:49 PM
Message I know these heads can be professionally ported well...I am just planning on smmothing the rough surfaces, opening up the ports(gaskets as guides)....any help is fine with me....don't really want to push it too much for the reason you pointed out....bu thanks, I saw no reason to clean pre-smoothing either.
Any more hints appreaciated, not starting tomorrow, have time to use, will slowly approach this...then off for rebuild, cams, BDE VTC gears.....so, winter project....pulled engine so many times, getting use to it.
Thanks
