TwinTurbo.NET: Nissan 300ZX forum - um... that's not the proper order for installation
jkperformance
on July 09, 2013 at 10:31 PM
clutch installed, unable to step on paddle ?
posted by tt_703
on July 09, 2013 at 09:50 PM
if you used that link, that's the problem. The friction disc goes INSIDE of the pressure plate and flywheel
tt_703
21:50:07 07/09/13
um... that's not the proper order for installation -
jkperformance
22:31:52 07/09/13
Corrected myself - of couse I did not install the clutch
tt_703
22:40:22 07/09/13
with the trans out, can you manually operate the fork and
jkperformance
22:52:30 07/09/13
Re: with the trans out, can you manually operate the fork and
tt_703
05:51:23 07/10/13
Stock fork and pivot ball?
Woody75 (Denver)
10:55:31 07/10/13
Re: Stock fork and pivot ball?
tt_703
11:21:15 07/10/13
Was the pivot ball shorter than the old one you removed? (n/m)
Woody75 (Denver)
13:36:49 07/10/13
unsure of that, again everthing worked fine a few month back (n/m)
tt_703
14:09:09 07/10/13
Oh, so the fork and ball were al ready in use?
Woody75 (Denver)
14:55:06 07/10/13
updated: just checked, yup the pivot ball on the trans is
tt_703
21:17:37 07/10/13
Is there any play when the slave is installed?
Woody75 (Denver)
22:16:27 07/10/13
