TwinTurbo.NET: Nissan 300ZX forum - Did it run right before the timing belt change, then start
Subject Did it run right before the timing belt change, then start
Posted by zellamay on July 06, 2013 at 7:22 PM
  This message has been viewed 149 times.
In Reply To overheating problem boiling over at radiator cap posted by jhop1988 on July 06, 2013 at 03:52 PM
Message to run hot? If so, one guess is that you're not getting all the air out when you fill it. There are many reasons for boiling over. The more description you give, the better responses you'll get. When does it do it? What is temp gauge reading before and during boiling over, compared to normal running position if you have a stock gauge? What makes you think the radiator is bad where the cap is? Did you check the fan clutch? Is the belt tension right?
