TwinTurbo.NET: Nissan 300ZX forum - Starter relay verified as working - Continuity meter
AlanC
on July 06, 2013 at 9:43 AM
when you turn the ign key do you hear the starter relay
posted by aliaZ
on July 06, 2013 at 07:56 AM
Worked around too many big machines in my life. Do not hear that well. The starter relay has two connectors. I left the coil hooked up and tested the other with a continuity meter. The relay works.
1991 Will not start - please help!
AlanC
19:53:00 07/05/13
no starter operation? (n/m)
BarryGZX
21:00:13 07/05/13
Re: no starter operation?
AlanC
21:58:19 07/05/13
You say the relay is good. I've read here that just because
zellamay
23:02:48 07/05/13
Re: You say the relay is good. I've read here that just because
AlanC
00:58:09 07/06/13
no voltage to starter... check ign switch voltage (n/m)
BarryGZX
05:22:38 07/06/13
Can you tell me where to probe?
AlanC
09:39:01 07/06/13
Re: Can you tell me where to probe?
aliaZ
13:15:57 07/06/13
aliaZ
07:56:21 07/06/13
Starter relay verified as working - Continuity meter -
AlanC
09:43:01 07/06/13
is the starter relay energized when you try to start? (n/m)
aliaZ
13:08:53 07/06/13
Yes - the starter relay is energized when I try to start
AlanC
13:19:27 07/06/13
Are you positive the clutch switch is being depressed
CmyZ
22:45:21 07/06/13
Positive switch is depressed - Cable tie
AlanC
09:52:00 07/07/13
Problem Resolved - Bad Starter Relay read on...
AlanC
21:16:09 07/08/13
Thank you for all the help !!! (n/m)
AlanC
21:19:53 07/08/13
Thanks for the feedback. So many times on this forum,
zellamay
08:25:05 07/10/13
