TwinTurbo.NET: Nissan 300ZX forum - Update: Got Readings After Draining Sender Hole
Subject Update: Got Readings After Draining Sender Hole
Posted by ThisIsSparTTa on July 03, 2013 at 8:17 AM
  This message has been viewed 285 times.
In Reply To Stumped - 2 Bad Oil Pressure Senders? posted by ThisIsSparTTa on July 01, 2013 at 10:17 PM
Message As an update, last night I unscrewed the oil pressure sender that was on there, and let some oil drain out into my drain pan, not a lot, but enough to drain out any blockages. I had cleaned my pan up previously, and with the new oil definitely came what looked like a little chunk of RTV and few metal shavings. I'm assuming this was stuff that kicked around from my spun bearing, etc. Anyways put the sender back on, and now I'm getting readings.
Lesson learned: Should have cleaned out the oil tree while I had it off the car for the rebuild, but wasn't on my mind
Also, someone mentioned the oil cooler. I actually did clean that out during the rebuild at the suggestion of Kyle(IPP) due to my spun bearing.
