TwinTurbo.NET: Nissan 300ZX forum - Re: The system is sensitive. OEM sender is unreliable.
Subject Re: The system is sensitive. OEM sender is unreliable.
Posted by bigsyke on July 02, 2013 at 11:28 PM
  This message has been viewed 200 times.
In Reply To The system is sensitive. OEM sender is unreliable. posted by OverZealous (CT) on July 02, 2013 at 10:21 PM
Message Dont forget the oil tree and the oil cooler. I was running extremely low oil pressure, sometimes it dropped to 0. Assumed it was the cluster or sender since I saw oil splashing around in the valve cover.
severly restricted the oil cooler and I'm always at ~60psi @2700rpms hot.
