TwinTurbo.NET: Nissan 300ZX forum - Re: Turbo Housings - Simple to separate?
Subject Re: Turbo Housings - Simple to separate?
Posted by GCamp on July 02, 2013 at 10:55 AM
  This message has been viewed 125 times.
In Reply To Turbo Housings - Simple to separate? posted by evan_aggie on June 27, 2013 at 03:57 PM
Message I just put new CHRAs in my twin and never done one before. I used a marker to mark where there they lined up. They will fit in any position. First lesson was to use Blaster PB spray on bolts to loosen them. Yes I broke the first one I tried to remove. Knowing my old CHRAs were bad I used a punch and hammer to tap the exhaust housing apart. Snap rings were easy to remove. Just make sure intake side O ring is in place prior to installing the housing. Exhaust side was pressed back together using the bolts a few turns each until all were tight. Not a hard job. Pulling and putting engine back in was the hardest part. Hope this is helpful for you.
