TwinTurbo.NET: Nissan 300ZX forum - Stumped - 2 Bad Oil Pressure Senders?
Subject Stumped - 2 Bad Oil Pressure Senders?
Posted by ThisIsSparTTa on July 01, 2013 at 10:17 PM
  This message has been viewed 262 times.
Message Long story short, just got done with my engine rebuild, and one thing that has been giving me trouble is my OEM oil pressure reading. Btw, I have a 91 TT. Before my rebuild, the gauge worked fine, afterwards it hasn't worked yet (more on this in a second). I'm fairly certain that I'm not getting 0 PSI oil pressure as I've probably idled addressing other various issues for around an hour now. I briefly pulled the oil cap off when the engine running and there was definitely oil kicking around.
Anyways, so first thing I thought was that some metal from my spun bearing had gotten into my original oil sender unit. Went to store and grabbed a new aftermarket, had the wrong connector. Grabbed my friend's one off an old NA engine that should have been working, and I'm still not getting a reading.
I've tested continuity from the sending unit to the connector near the passenger headlights, and then inside the car at the passenger side kick panel connector. I was about to pull the gauge cluster tonight when I read that I could first try the circuit open (what it effectively had been) and get a 0 reading, then ground it and get a full reading...and to my surprise the gauge moved all the way up. Btw, this was connected to the oil sender connector under the car.
Now I don't see any reason to pull the gauge cluster. I took my old "bad" unit, hooked it up to the signal wire and ground, connected an air compressor to it, and got no reading. I don't have an easy way to pull the "new" one off without draining the oil.
Is there something I'm missing here, or did I get unlucky with possibly a 2nd bad sender unit? If I were to get a new one and it still failed, what would be my next steps? I'm pretty stumped.
