TwinTurbo.NET: Nissan 300ZX forum - Re: Hi, so many things.... particually with mods..
Subject Re: Hi, so many things.... particually with mods..
Posted by Drunkpunk082 on June 29, 2013 at 12:07 PM
  This message has been viewed 463 times.
In Reply To Hi, so many things.... particually with mods.. posted by Medallion Man on June 29, 2013 at 11:00 AM
Message Okay let me eliminate some stuff for you guys. EFI harness is brand new, no corrosion on ANY connectors. Motor was pulled during 5 speed swap. All leaks were resealed, so absoutly no boost or vacuum leaks. Timing is set at 15 degrees, haven't pulled ECU codes yet but I will do that tonight.
Plugs, filters, all regular maintence is up to date. I will run a test on the temp sensor.
