Is purge canister removed or disconnected? Knock harness check connections. You can do a quick fix on it and repair harness but if knock sensor is bad either replace or you can use, I believe a 1000moh resistor between contacts on harness going to ecu to imitate a good voltage. Check the ohms for the resistor, I know Z1 sells a kit but its easy to do yourself
