TwinTurbo.NET: Nissan 300ZX forum - Re: Did you run the ABS diagnostic code? Might help to track
Subject Re: Did you run the ABS diagnostic code? Might help to track
Posted by VG30DE on June 25, 2013 at 10:25 PM
  This message has been viewed 248 times.
In Reply To Did you run the ABS diagnostic code? Might help to track posted by jzack on June 25, 2013 at 10:03 PM
Message Yes I did check all of the abs wires and sensors. The abs actuator pump was acting up prior to the z being stored for a long period of time. I think the period of inactivity just finished what ever was already happening. I have read some posts and most change the abs relay which is the cheapest fix. There are some that have had the misfortune of having the pump burn up. I don't think that's my case cause my pump was acting up intermittently. Now the abs light stays on and the abs pump is quiet.
