TwinTurbo.NET: Nissan 300ZX forum - Did you run the ABS diagnostic code? Might help to track
Subject Did you run the ABS diagnostic code? Might help to track
Posted by jzack on June 25, 2013 at 10:03 PM
  This message has been viewed 245 times.
In Reply To Abs relay location ? posted by VG30DE on June 25, 2013 at 06:52 PM
Message down why the light flashes?
One potential issue, one of the front wheel sensor wires is partially freyed - turning the car a certain way causes the ABS to read a bad condition. Had that issue with my Z - local mechanic told me over time due to suspension up/down motion the wiring between the abs wheel sensor and the car's harness runs into issues. I installed a used but good working sensor on the psgnr side front hub and all has been good since.
