TwinTurbo.NET: Nissan 300ZX forum - A couple of things.....
Subject A couple of things.....
Posted by 280ZuL8R on June 24, 2013 at 8:11 PM
  This message has been viewed 173 times.
In Reply To Paint peeling off posted by quadratique on June 23, 2013 at 09:20 PM
Message -What grit/pad did you prep with?
-Did you wipe it clean with wax/grease remover followed by a tack cloth as your last step before priming?
-What primer did you use?
-Was it single stage or two part?
-What thinner and what application method did you use?
-What were the conditions during coating (temp,humidity)?
-Was it a non sanding primer, or were you supposed to sand before basecoat?
-How long did you wait before applying your basecoat?
as/image_zps3cb9dfb3.jpg>
1980 Datsun 280zx
1991 Nissan 300zx TT
2006 Nissan 350z
