TwinTurbo.NET: Nissan 300ZX forum - Pin #44 on the ECU is for the neutral switch.
Subject Pin #44 on the ECU is for the neutral switch.
Posted by xpwarrior on June 24, 2013 at 7:55 PM
  This message has been viewed 189 times.
In Reply To Neutral Safety Wire Splice for an AT to MT Conversion? posted by Jayru on June 22, 2013 at 06:31 PM
Message If you use the ECU programmed for the auto trans your timing will be advanced 5 degrees when it thinks it's in gear.
If you chip the ECU with a tune for a 5 speed you can just leave the wire disconnected which will make it think it's in gear all the time. This doesn't appear to cause any problems and that's how I have had mine for years.
