TwinTurbo.NET: Nissan 300ZX forum - Check your TPS and connections
ThisIsSparTTa
on June 24, 2013 at 2:05 PM
Re: Revving Idle after Plenum Pull
posted by weezee
on June 23, 2013 at 06:55 PM
My friend has a similar issue where his TPS won't recognize 0 throttle. Basically the TPS has 3 states, idle, open and WOT. The ECU only uses the first 2. I think you can see what the ECUthinks the state is via Consult.
weezee
18:53:49 06/23/13
weezee
18:55:26 06/23/13
Vacuum leak, do a boost leak test if you can
ttsmokin
21:21:50 06/23/13
Check your TPS and connections -
ThisIsSparTTa
14:05:26 06/24/13
jpuga
23:06:52 06/24/13
A simple thing to check is the throttle cable; is it adjuste
Haasz32
15:19:58 06/28/13
