TwinTurbo.NET: Nissan 300ZX forum - Vacuum leak, do a boost leak test if you can
ttsmokin
on June 23, 2013 at 9:21 PM
Re: Revving Idle after Plenum Pull
posted by weezee
on June 23, 2013 at 06:55 PM
If not grab a can of brake cleaner and shoot it in a few areas around the plenum, the idle will change if there is a leak somewhere.
weezee
18:53:49 06/23/13
weezee
18:55:26 06/23/13
Vacuum leak, do a boost leak test if you can -
ttsmokin
21:21:50 06/23/13
Check your TPS and connections
ThisIsSparTTa
14:05:26 06/24/13
jpuga
23:06:52 06/24/13
A simple thing to check is the throttle cable; is it adjuste
Haasz32
15:19:58 06/28/13
