TwinTurbo.NET: Nissan 300ZX forum - Revving Idle after Plenum Pull
Subject Revving Idle after Plenum Pull
Posted by weezee on June 23, 2013 at 6:53 PM
  This message has been viewed 200 times.
Message So I just put the car back together after doing a plenum pull to replace my valve cover gaskets, and when I start it up, it constantly revs back and forth between 1800-2000 RPMs. I've checked for codes and do not have any. I've checked all of the electrical connectors and vacuum lines and everything seems good and tight. No leaks that I can find. I'm going to check the IACV and the TPS next, but does anyone have other suggestions on what to check?
Thanks!
“Gentlemen, you can’t fight in here! This is the War Room!" — Dr. Strangelove
