TwinTurbo.NET: Nissan 300ZX forum - If not the ECU temp sender, check your air regulator
ttsmokin
on June 23, 2013 at 2:37 PM
Cold start idle issue continues.. Help!
posted by GotTwins90
on June 22, 2013 at 08:01 PM
It bumps up the idle on a cold start, although if you have it completely deleted the IACV will take over on a cold start and keep the idle high.
GotTwins90
20:01:25 06/22/13
Did you say you checked the ECU temp sender unit? (n/m)
Medallion Man
03:05:48 06/23/13
No but ill definitely give it a try. Thanks! (n/m)
GotTwins90
09:31:30 06/23/13
If not the ECU temp sender, check your air regulator -
ttsmokin
14:37:00 06/23/13
Will do! Thanks! (n/m)
GotTwins90
18:35:20 06/23/13
