TwinTurbo.NET: Nissan 300ZX forum - Thanks- a few questions >>>
Subject Thanks- a few questions >>>
Posted by stockplayerz(nyc) on June 23, 2013 at 1:21 AM
  This message has been viewed 202 times.
In Reply To My advice - I'd probably elect to start by removing posted by jzack on June 21, 2013 at 09:32 PM
Message The short coolant lines you mention that are behind the pipes- can you see them without taking pipes off? How many are there? Just took a closer look today, and theres coolant leaking under the car, right around the center where the water pump is. But couldn't tell if it's a hose leaking or wp. Will I be able to check this by taking only the drivers side tb cover off? Thanks again!
