TwinTurbo.NET: Nissan 300ZX forum - Neutral Safety Wire Splice for an AT to MT Conversion?
Subject Neutral Safety Wire Splice for an AT to MT Conversion?
Posted by Jayru on June 22, 2013 at 6:31 PM
  This message has been viewed 322 times.
Message Question for any of you who've done an AT to MT swap. I'm using the TT alt/trans harness - and am de-pining the 8 prong MT plug and swapping the 4 wires (VSS & Alt) that are in the same location on the AT 6 prong harness. I'll leave the last 2 empty (they're for the AT inhibitor switch). This way, I have a factory looking harness / plug with the wires for the reverse lights right there from the factory harness (and will splice them into the old AT control harness plug).
But the one thing I can't figure out, is where the single wire for the neutral safety wire splices into? There are two on the sensor, but only one on the plug - I'm assuming the black goes to ground in the trans harness, so where does the signal come from for the neutral safety? I don't see any such pin on the ECU schematic. Anyone know?
93 2+2 Twin Turbo Track Build - jsworks.org for more info!
