TwinTurbo.NET: Nissan 300ZX forum - Re: help with a/c
Subject Re: help with a/c
Posted by reaperz1 on June 17, 2013 at 4:46 PM
  This message has been viewed 133 times.
In Reply To help with a/c posted by reaperz1 on June 17, 2013 at 02:07 PM
Message so i decided to put the whole test with results to see if i can get more help
so i held auto/off for 5 seconds this is what happened
24 ac did not come on display showed def
then i started to click the angle switch where you want the air to blow. this is the results i got
98 arrow pointed toward you
75 arrow pointed to feet
68 def
53 arrow pointed you
59 arrow pointed to feet
34 def
76 arrow pointed you
11 arrow pointed to feet
0 def
62 arrow pointed to feet
30 def
27 arrow pointed you
99 arrow pointed to feet
2 arrow pointed you
51 arrow pointed to feet
Then I clicked auto, then i clicked the angle switch where you want the air to blow. this is the results
48 def
29 def and the arrow pointed to your feet
12 arrow pointed to you, and arrow pointed to feet
it went 1 and paused for second then it went to 0 the arrow ponted to you and the cold air came out
pushed auto this is using the angle switch to control where you want the air to blow
2
3
6
7
9
11
12
15
16
18
20
21
24
25
27
29
30
33
34
36
this is the opposite direction useing the fan speed switch
0
-2
-3
-6
-7
-9
2
3
6
7
9
11
12
15
16
18
20
21
24
25
27
29
30
33
34
36
pushed auto, used the angle switch where you want the air to blow
0 Def with no fan display
50 arrow pointed to you with no fan display
50 arrow pointed to feet with no fan display
50 def with fan display
50 arrow pointed to you with fan display
50 arrow pointed to feet with fan display
50 def with fan display, and fan speed on 1
