TwinTurbo.NET: Nissan 300ZX forum - Anything is possible, but its not likely.
Summeronthechain (MN)
on June 17, 2013 at 8:16 AM
Can an injector still be bad if it ohms well and pulses?
posted by TriniTT
on June 17, 2013 at 08:12 AM
When the engine is running and you put a screwdriver on the injector and your ear to the other end can you hear it ticking?
TriniTT
08:12:17 06/17/13
Anything is possible, but its not likely. -
08:16:06 06/17/13
I grabbed a noid light at lunch and hooked it up to make
TriniTT
12:00:37 06/17/13
Could be a bad injector driver. Have you ohm'd out the
Evan_Wright (Ca)
15:45:17 06/17/13
I've had clogged injectors do this.
Woody75 (Denver)
11:15:18 06/17/13
They could be clogged. In the ohm measurement you >>>
ZUL8TR
11:16:12 06/17/13
What was the issue? Misfire?
300ZMang
13:32:07 06/17/13
read it - cyls 1 and 5 aren't firing (n/m)
TriniTT
14:21:23 06/17/13
Well Mr. Know-it-all
300ZMang
16:43:07 06/17/13
You should probably not troll the tech forum. (n/m)
TriniTT
19:31:52 06/17/13
Found it - the white injector subharness connector by the
TriniTT
17:15:49 06/17/13
Nice! Got to love those easy fixes. (n/m)
Evan_Wright (Ca)
17:37:01 06/17/13
Indeed :) now to find my boost leak! (n/m)
TriniTT
18:18:13 06/17/13
