TwinTurbo.NET: Nissan 300ZX forum - Can an injector still be bad if it ohms well and pulses?
Subject Can an injector still be bad if it ohms well and pulses?
Posted by TriniTT on June 17, 2013 at 8:12 AM
  This message has been viewed 314 times.
Message I'm working on an issue with my ttz, everything is 95-style so newer injectors/cas/harness/etc. I started it the other day and it wasn't running proparly. I pulled the coil pac connectors for each cylinder and determined cyls 1 and 5 aren't firing; i.e. there was no change when the coil pack connector was pulled. I ohmed the injectors and they ohm at 12v, I checked for spark by removing the plug/pack and I'm getting spark, I also swapped them around from working cyls. I sent 12v directly to the injectors for those cyls and they click, pulled the CAS and rotated and I get 6 clicks for each complete rotation.
So I have spark, and from what I can tell, fuel. Compression is in the 150 range for all cyls. Is it possible for an injector to not be sending fuel despite the fact that it clicks/sounds and ohms normal?
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
