| most likely fuse/s blown, check your fuse box (all three) and earths. I would be taking all the harness' off and redoing them. but first try the timing again, tie the clamp open on the pickup and place it behind the #1 coilpack and try it that way.. also make sure the white line on the pulley is clearly visible. can I assume you did the timing belt and checked that the pulley did line up right and counted cogs. it sounds like the timing is way out to me. good luck.
