TwinTurbo.NET: Nissan 300ZX forum - Figured it out.
Subject Figured it out.
Posted by ZiNnYc on June 16, 2013 at 8:22 PM
  This message has been viewed 217 times.
In Reply To No fuel on cylinder 4, suggestions needed posted by ZiNnYc on June 16, 2013 at 06:11 PM
Message Pin 112 on the ECU HARNESS! side was bent, causing a failure in connection. The loop wire between all the injectors was stable, hence only one wire reading battery voltage thusly causing the cylinder to drop.
[ http://www.karljapetre.com/z/ecu/eccs-color.gif ]
