TwinTurbo.NET: Nissan 300ZX forum - No fuel on cylinder 4, suggestions needed
Subject No fuel on cylinder 4, suggestions needed
Posted by ZiNnYc on June 16, 2013 at 6:11 PM
  This message has been viewed 202 times.
Message I have a no fuel condition on cylinder 4. Spark has been ruled out, coil pack has been tested and provides spark when SP is inserted and grounded.
I have Injector Dynamics 1000cc injectors that have pigtails soldered onto the main harness. Other injectors get battery voltage on both wires, except cylinder 4 which only gets battery voltage on one wire. The other wire is pretty much doing nothing.
This condition exists before the pigtail solder location and after the solder point (doesn't change).
The CAS was replaced, and the PTU was replaced.
Thanks in advance, this is the single issue that's holding me back! (until I find others)
