TwinTurbo.NET: Nissan 300ZX forum - You need to perform a leak down test to determine
Subject You need to perform a leak down test to determine
Posted by SammybTT(TN) on June 15, 2013 at 10:28 PM
  This message has been viewed 158 times.
In Reply To low compression on new engine. posted by gbeto on June 15, 2013 at 09:46 PM
Message the cause of low compression. Could be valves, head gasket, rings, pistons, or a cracked block or head. The test will help isolate. Of course the turbos will need replaced/rebuilt. And as you mentioned a good idea to perform the maintenance items (timing belt, water pump, thermostat, etc). These engines get very expensive fast especially if you have to pay for the labor. Good luck
