TwinTurbo.NET: Nissan 300ZX forum - Re: running rich
Subject Re: running rich
Posted by jerdobi on June 14, 2013 at 7:56 PM
  This message has been viewed 181 times.
In Reply To running rich posted by oscarstt on June 13, 2013 at 08:15 PM
Message You need to install a wide band o2 sensor and gauge or take to shop that can add one and measure the fuel ratio at idle and wide open. You then new socket the ECU and tune it at a shop or use Tunerpro and do it yourself. Most new injectors flow more than spec so run rich along with chip tuners make them rich to be conservative not to blow your engine.
