TwinTurbo.NET: Nissan 300ZX forum - Re: Bad Alternator Whine in Sound System
Subject Re: Bad Alternator Whine in Sound System
Posted by zcarlvr on June 13, 2013 at 6:21 AM
  This message has been viewed 298 times.
In Reply To Bad Alternator Whine in Sound System posted by WE350Z on June 10, 2013 at 04:03 PM
Message I'll suggest running a separate ground from the battery to the amp. this will eliminate the need for an isolator. I've never had any whine noise with this practice. You can use a long Positive wire kit as it's just a piece of wire. You can try a temporary connection outside and around the car to see if it helps before installing the wire.
