TwinTurbo.NET: Nissan 300ZX forum - Also, your alternator is probably bad.
Subject Also, your alternator is probably bad.
Posted by TriniTT on June 12, 2013 at 11:57 AM
  This message has been viewed 206 times.
In Reply To It's probably your window motor amplifier. posted by TriniTT on June 11, 2013 at 08:55 AM
Message Replacing the battery will make you think it's working fine, but I doubt the alternator is charging to capacity based on your description. It's charging some, but if you had to replace your battery, the alternator is likely the culprit.
This is a separate issue from the window issue.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
