TwinTurbo.NET: Nissan 300ZX forum - Manually turn the engine over by the crankshaft pulley
SammybTT(TN)
on June 12, 2013 at 11:47 AM
everything is connected. fuses are good
posted by Stanky
on June 12, 2013 at 09:28 AM
This will confirm there isn't something binding. If it rotates I would suspect the starter since the solenoid is engaging. Sometimes a good "tap" on the starter will get it going, especially if it is the solenoid. Hope this helps.
First start after rebuild, car wont crank
Stanky
00:30:51 06/12/13
is this a test start or is everything connected?
Medallion Man
03:13:18 06/12/13
Stanky
09:28:11 06/12/13
Manually turn the engine over by the crankshaft pulley -
SammybTT(TN)
11:47:07 06/12/13
crankshaft spins feely, and I gave the starter a tap
Stanky
12:55:19 06/12/13
SammybTT(TN)
08:00:45 06/13/13
You are getting juice, but not enough, so it's not a relay
zellamay
12:14:02 06/12/13
Try battery charger in 'Start' mode or a jump (n/m)
ThisIsSparTTa
12:23:52 06/12/13
