TwinTurbo.NET: Nissan 300ZX forum - Mmmm, are both O2s working OK?
Medallion Man
on June 11, 2013 at 1:31 AM
Also have a photo of the plugs, one bank is running leaner
posted by ttsmokin
on June 11, 2013 at 01:10 AM
Have you done a vac leak test?
Have you done a TB balance and clean?
Idle issues
ttsmokin
22:17:30 06/09/13
Can we assume you’ve done all the connector checks and clean
Medallion Man
02:10:00 06/10/13
X2, check injectors and CAS. Also timing belt? (n/m)
Summeronthechain (MN)
09:42:32 06/10/13
Here are the following tests I have done:
ttsmokin
22:09:09 06/10/13
ttsmokin
01:10:11 06/11/13
Mmmm, are both O2s working OK? -
Medallion Man
01:31:28 06/11/13
you might as well give the IAA and air reg a clean as well. (n/m)
Medallion Man
01:33:53 06/11/13
You sir deserve a medallion!
ttsmokin
19:31:04 06/11/13
glad you resolved it.. :¬) (n/m)
Medallion Man
03:05:51 06/12/13
At 2k rpm both 02 sensors fluctuate between lean and rich
ttsmokin
01:50:00 06/11/13
