| Message |
It has to do with what sound the amplifier is amplifying. All speakers should have the wine. If you're in doubt, you could try cause it only takes 5 seconds to undo each speaker from the amp. Just some food for thought, did you properly ground the amp wire as well? Strip away paint with a dremel so you have the best connection to the ground of the chassis? Having a good ground goes a LONG way. The distance between your power wires and the RCA's I believe should be ample, but if after confirming the grounds are all good, my next step would be the RCA location.
