TwinTurbo.NET: Nissan 300ZX forum - For 1 and 3,
Subject For 1 and 3,
Posted by TriniTT on June 08, 2013 at 4:38 PM
  This message has been viewed 200 times.
In Reply To Weird little annoyances with my Z ... Help =\ posted by 300zxNA2TT on June 08, 2013 at 02:05 PM
Message 1. Chances are part of the door lock plastic piece is broken directly on the inside of the handle and this is not registering when you use the key in the door lock. Easy to check/fix, just remove the door handle to inspect.
3. HIDs can be squirrelly, get an HID subharness that runs directly off battery power and only uses the headlight plug as a switch, they're cheap off eBay and universal. Upside to this is it will not cut off your HIDs wen you turn on your high beams, which is why all Zs should use the subharness anyway. Switching on/off HIDs is unhealthy for them.
Sorry, I can't help with #2.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
