TwinTurbo.NET: Nissan 300ZX forum - Throttle body adjustment question
Subject Throttle body adjustment question
Posted by Da Flash on June 07, 2013 at 9:40 PM
  This message has been viewed 663 times.
Message I am trying to fix a high idle issue (1100 rpms with AAC, 700 without) and I've gotten around to cleaning/adjusting the TB's. I am follow this thread from Wiki32;
[ http://z32.wikispaces.com/Throttle+Body ]
As far as the butterflies it says "There is a vacuum port on the underside of each throttle body. When the valve is fully closed you should be able to see the opening for this port from the inside. Turn the peg until the throttle closes all the way and this port is visible."
On the passenger side TB the butterfly is sitting about half a hole behind the "vacuum port" but on the drivers side the the butterfly is covering the last ~1/3 of the port ( this is looking from the outside/hose side of the TB )
My question is, what is the proper place for the butterflies in reference to the vacuum port?? Also would this contribute to my high idle??
TIA!!
