TwinTurbo.NET: Nissan 300ZX forum - The bolts may get stuck from crud between the caps and bolts
Subject The bolts may get stuck from crud between the caps and bolts
Posted by ZXoltan on June 06, 2013 at 7:18 PM
  This message has been viewed 208 times.
In Reply To cam cap question posted by 1995z32tt on June 06, 2013 at 02:49 PM
Message You can get them unstuck if you are careful. Soak them in carb cleaner for a few days and then spray some penetrating oil down into them. You should be able to wrench on the bolts to get them to turn (put caps in a vice if necessary). Once they are freed up a bit, you can tap the bolts out. Best way is to rest the threaded part of the bolt on a rag or piece of wood and tap the cap down toward the bench, driving the bolt upward. Don't tap on the threaded part of the bolt or you risk mushrooming the bolt, unless you have a brass hammer.
If you use a different/ unmatched cap you will have to get it "line bored" out so it lines up with the cam bore. Unfortunately it is very difficult to find a shop that has the correct machinery to do this and thus more than likely very 'spensive.
