TwinTurbo.NET: Nissan 300ZX forum - Re: High idle, ~1100rpms with aac plugged in, ~700rpms without
Subject Re: High idle, ~1100rpms with aac plugged in, ~700rpms without
Posted by Da Flash on June 06, 2013 at 3:19 PM
  This message has been viewed 282 times.
In Reply To High idle, ~1100rpms with aac plugged in, ~700rpms without posted by Da Flash on June 02, 2013 at 06:28 PM
Message I decided to pull the air reg and ohm it out again. It still shows ~77 ohms but when I do the 12v test on the solenoid, the shutter doesn't move at all, can the air reg be bad and still not make the idle go down when the hose going to the balance tube is pinched???
